WIFI calling not working
  • Dec 15, 2022 11:13 AM UTC
  • 16 replies
  • 766 views
Hello
I have read many of the threads about WIFI calling and it looks like I need to be flagged so a rep can fix my account. WIFI calling does not accept my phone number for e911 and I have tried all suggestions. I need this for work please help fast
Galaxy s20
Best answer by Chris Koodo
@John1818 - I just went in and added the add-on for you. You may need to restart your phone before seeing the option.
  • Dec 15, 2022 2:27 PM UTC
Before flaging, would you mind to confirm if you are a postpaid customer and your S20 is a Canadian model phone? Also, can you log into your selfserve, check the addon area and see if you have the volte access addon or not?
  • Dec 15, 2022 2:36 PM UTC
Are you using the same email address for Self Serve as here in the community?
This allows the rep to access your account and send private messages if necessary.
  • Dec 15, 2022 2:39 PM UTC
Hello
Yes this is the same email as my account.
Dinh:  I am postpaid yes it’s a canadian phone. I checked the add on area and VOLTE is not there nor is there an option to add but the other threads mention this as well. I got the app to check VOLTE and yes it’s turned on.
I did all the things. Help
  • Dec 15, 2022 2:49 PM UTC
Hello
Thank you. Either one of us can flag a rep, but because Dinh replied to your post first, I want to avoid double-flagging a rep.
Chris Koodo
  • Dec 15, 2022 2:56 PM UTC
  • Dec 15, 2022 3:09 PM UTC
@Chris Koodo Thanks Chris. I see the change on my account but when prompted for my number it says koodo doesn’t recognize it so it still doesn’t work. I restarted my phone twice to be sure. Any advice?
Chris Koodo
  • Dec 15, 2022 3:41 PM UTC
@John1818 - Can you try again please. I just reset the add-on another time
  • Dec 15, 2022 3:45 PM UTC
@Chris Koodo - I restarted my phone and tried to enable WIFI calling. It then prompts me for my phone number so it can text me a code but gives me the error “The number entered doesn’t match our records.”
  • Dec 15, 2022 5:13 PM UTC
Just giving this a bump as I still am having the same issue.
  • Dec 15, 2022 5:31 PM UTC
The next step, according to a rep's comment in a similar post, is that they recommend scheduling a callback so they can further investigate and get tech support involved. Please use Koodo Assist to schedule a callback.
  • Dec 15, 2022 5:35 PM UTC
Yeah which is 2 days from now. My old carrier now that i left is matching the offer with more data it may be easier to leave since I kept the sim card. What kind of company doesn’t have a customer service phone line???
  • Dec 15, 2022 5:43 PM UTC
Try this link here to see if this resolves the issue.
  • Dec 15, 2022 5:45 PM UTC
Same problem. I tried that from an earlier thread I read about it and I also tried again now error message :“ The number entered doesn't match our records. Please re-enter your number. “
  • Dec 15, 2022 5:56 PM UTC
Unfortunately, I do not have access to internal phone numbers. A quick look on Reddit might prove useful. If your old carrier is offering a better deal with less hassle, go for it.
  • Dec 15, 2022 5:57 PM UTC
This isn’t fixed by end of my work day I’m going back to bell what a terrible experience. They all suck but at least they answer the phone. Why couldn’t they offer me the plan they are now before ($42 for 25GB) I left and wasted all this time with koodo... But it’s a base plan with a applied credit so have to switch again after that Ugh. At least I’m getting the rate I wanted but not without pulling a few teeth ffs. So glad I didn’t chuck the sim card lol. Thanks for your time rikkster
  • Dec 15, 2022 7:26 PM UTC
Ok it’s been fun thanks for the “help” I guess it is technically solved now because I left.
