WIFI Calling Issue - The Number Entered Doesn't match or records.
  • Oct 22, 2026 1:55 AM UTC
  • 10 replies
  • 103 views
Hello,
I have a Samsung Galaxy S25 Ultra.  I have a postpaid account and moved to a place that has no signal in the basement (Where i work) and when i try to set up wifi calling I get the above message:   The Number Entered Doesn't match or records.  When I try to call in I get no answer, and am directed to the chat bot who just goes in circles and doesn’t give me an option to call anyone.  Any way i can resolve this?  Wifi calling is important and I will have to move to another carrier if I can’t use it.
Best answer by Georgia Koodo
Hi ​@AJRehman, we’ve attached your number profile to your online account, please try to activate the Wi-Fi calling again. Let us know if it worked!
  • Oct 22, 2026 2:58 AM UTC
There's no separate VoLTE add-on to add on your account, VoLTE is auto-provisioned in Koodo's carrier settings on newer plans.
Did you recently port or transfer this number to Koodo? On a freshly ported line that error usually means the transfer hasn't fully completed on Koodo's end rather than an actual Wi-Fi calling fault. As well, did you try enabling it while the phone had Koodo cellular signal? On Android you sometimes have to turn Wi-Fi calling back on after being out of network range, so I would try the activation upstairs rather than in the basement.
I would also reset the network settings on the S25 Ultra and try again. https://www.koodomobile.com/en/help/wifi-calling
  • Oct 22, 2026 3:22 AM UTC
Thank you ufor your replay.
I did port my number from Rogers.  6 years ago.  I've only recently moved my office to the basement.  Yes I tried enabling while having coverage.  Same issue.
 Network reset didn't work.  Same issue as before.
  • Oct 22, 2026 4:43 AM UTC
Let me flag a rep to see if the VoWiFi is provisioned properly on your line.
I assume your S25 Ultra is a North American model?
  • Oct 22, 2026 5:33 AM UTC
You will need to request a callback via koodo assist and a rep can investigate.
This has happened to me in the past and typically it fixes itself after a few weeks. But if you need wifi calling  now a rep will need to look into this.
  • Oct 22, 2026 5:39 AM UTC
Yes.  The s25 ultra was bought from Samsung in Canada brand new.   When it first launched
  • Oct 22, 2026 6:56 PM UTC
  • Oct 23, 2026 1:18 AM UTC
That did the trick!   I am now able to make calls from my basement thank you so much.
  • Member
  • Nov 4, 2026 5:42 PM UTC
I’ve the same issue than AJRedman. Would it be possible to my number profile to my online account aka get the same fix?
  • Nov 4, 2026 6:29 PM UTC
Hello ​@JFB we’ve attached your number profile to your online account, please try to activate the Wi-Fi calling again. Let us know if it worked!
  • Member
  • Nov 5, 2026 9:51 AM UTC
Thank you! The issue is fix, I was able to activate wi-fi calling.
