VoLTE and WiFi Calling not working
  • Jan 19, 2023 2:31 PM UTC
  • 514 views
Hi,
I just ported my number over to koodo and my WiFi calling can not active from my phone setting even though each time when I tried to enable it I was then redirected to Koodo’s website to complete a 2FA then confirm my address. After being redirected back to the phone setting the WiF i calling is still disabled as the service request eventually timed out.
My phone model is Samsung S22 Ultra
Could I get some help please?
  • Jan 19, 2023 2:51 PM UTC
You might not have VoLTE activated on your account for some reason. How recently did you port over?
Toronto_koodo
May be unable to verify your geographical location. Some settings in your phone could disabled location visibility. WiFi calling only works in Canada
  • Jan 19, 2023 3:19 PM UTC
I’m in Toronto, and I can’t recall or find any suspicious setting that might have disabled the location visibility.
  • Jan 20, 2023 12:30 PM UTC
The VoLTE access add-on has to be added to your account for Wi-Fi Calling to work. The add-on may have already been added.
To check, log in to your Self Serve account. Click/tap the Self Serve tab and select Mobile services. Click on My add-ons and check that the VoLTE access add-on is visible in the list of add-ons. If the VoLTE add-on is not visible, we can flag a rep to add this to your account.
If the VoLTE access add-on is visible in your Self Serve account and you cannot enable Wi-Fi Calling, the next step is to schedule a callback via Koodo Assist. Enter “schedule callback” (without quotation marks) into the chat window and follow the prompts. At the start of the callback, explain the problem and ask to speak with a tech support agent.
  • Jan 20, 2023 4:34 PM UTC
Thank you all. I do have VoLTE add-on in my Self Serve upon checking. But Wi-Fi calling doesn’t seem to be working properly. The enable switch in my phone setting sometimes turned itself off for some reason (WiFi was present and signal was strong), and I wasn’t able to enable it when the issue happened. I will try Koodo Asset when that happens. Thanks again.
  • Jan 21, 2023 3:04 AM UTC
I think there was a bug with WiFi calling of Android devices. Sometimes, you would have to reactivate wifi calling again.
Also, Koodo wifi calling prioritized "cellular signal" over wifi signal, so wifi calling would only show up when the cellular signal was bad and your internet ISP didn't block it.
