Voicemail needs reset
  • Sep 22, 2022 9:01 PM UTC
  • 7 replies
  • 455 views
My voicemail keeps giving me an error message for the past few days. From previous posts I understand that a tech needs to reset it.  Asking for a tech to please do this for me, thank you!
Best answer by Boa_Guy Koodo
Hi there @Adam H . We have reset your voicemail. You can set it up and let us know if everything is back to normal.
Cheers, :)
  • Sep 23, 2022 3:10 AM UTC
I’ve flagged a rep to help you with this. Due to the time of day, you may not hear back from the rep until tomorrow.
Boa_Guy Koodo
  • Koodo Alumni
  • Sep 23, 2022 11:35 AM UTC
Cheers, :)
  • Sep 25, 2022 4:50 PM UTC
Hi, thanks for doing this but unfortunately I keep getting the same error.  When I try to call voicemail my phone (iPhone 8) goes to a screen that says “Error Performing Request - Unknown Error”.  The only option is to push a button “Dismiss”.  When I do this it returns to the call screen but does not connect to voice mail.  When I end the call it indicates “Call Failed”.
How do we proceed?
Thank you,
Adam
  • Oct 20, 2022 6:14 PM UTC
I’m an also having the error message and have needed my voice mail reset since I joined Koodo in the summer. So frustrating!
Boa_Guy Koodo
@Jody M  Here is a helpful article that should fix your issue.
  • Member
  • Oct 27, 2022 6:10 PM UTC
I am also having this problem. Getting message “1 uv1 caller not available”. Can you reset mine?
  • Oct 27, 2022 6:55 PM UTC
That’s a little different. It usually means the person you are trying to reach is not available. It could be that their phone is turned off, or that the person accidentally blocked your number, or perhaps the person is out of the service area and cannot receive calls.
