Voicemail calls keep failing
  • Mar 1, 2022 3:45 PM UTC
  • 13 replies
  • 2725 views
My voicemail hasn’t worked for the last several days. Every time I attempt to call it I either get an ‘Error performing request Unknown error’ message or it connects and is completely silent. When it connects and I end the call, I get a call failed message
Seems to be the same issue here:
Best answer by Julia Koodo
Hello! Your voicemail has been reset. Please make sure to power your phone off & on now and keep us posted if the issue persists.
  • Mar 1, 2022 6:37 PM UTC
According to the linked post you’ve provided, it looks like a rep will have to reset your voicemail service. I’ve flagged a rep to help you with this.
Julia Koodo
  • Mar 1, 2022 8:51 PM UTC
  • Mar 2, 2022 10:49 PM UTC
Confirming resetting the voicemail took care of this issue
Bryan Allemang
How do I reset it? Mine is doing the same thing.
  • Apr 3, 2022 12:30 AM UTC
A rep will have to perform the voicemail reset. I’ve flagged a rep to help you with this.
Julia Koodo
  • Apr 4, 2022 1:54 AM UTC
Hello! The voicemail has been reset. Please keep us posted if you need more help and also feel free to check out this link https://www.koodomobile.com/en/help/voicemail?search_api_views_article_search_fulltext=voicemail if you’d like to review the details of the voicemail feature.
  • Member
  • May 26, 2022 2:33 PM UTC
Could a rep please reset my voicemail as I also keep getting an error message when I try to access it.
  • Jun 1, 2022 4:07 PM UTC
Hi there, could I have a rep reset my voicemail as well? It was also getting an error messgage and has been for a couple of days.
  • Member
  • Jun 27, 2022 7:27 PM UTC
Hi, could I please have a rep reset my voicemail. It has not worked for over a week, and I keep getting the error message. Thank you @Koodo
  • Jun 27, 2022 7:58 PM UTC
Hello @ktank! I have reset your voicemail, please restart your phone and check this article.
@LynEAW @snh so sorry for the late reply, we’ve just seen your comments. Do you still need assistance with this?
  • Organizer
  • Sep 2, 2022 9:38 PM UTC
Mine is doing the same thing, can someone reset my voicemail as well?
  • Sep 3, 2022 5:45 PM UTC
Hello @Kman777! I’ve just reset your voicemail as well, please restart your phone and check this article to see how you can set up your voicemail again.
  • Organizer
  • Sep 3, 2022 6:40 PM UTC
Thank you so much
