visual voicemail
  • February 12, 2026
  • 3 replies
  • 50 views
Chark
In my plan I have visual voicemail. I set up my voicemail. I used to get notifications on my dropdown menu with old voicemail. I would click on my notification and my voicemail would show up. Now with visual voicemail I get it in my text messages and I can listen but I can't delete or anything but listen to my email. If I want do anything I would have to dial my # and go to voicemail. Is there anyway I can get into it(menu) from my text
  • February 12, 2026
Hi ​@Chark, you have the Premium Voicemail perk which is not the same as Visual Voicemail.
Premium Voicemail will Increase the voicemail storage to hold up to 25 messages, and give you access to Instant Voicemail to send voicemails to your device via MMS.
If you’d like to add Visual Voicemail instead, you can do so in your online account for $8 per month, more information on it here
Chark
  • Organizer
  • February 12, 2026
Sorry I did mean the instant voicemail but I don't get notified in dropdown menu like I used to.cant delete unless I dial my voicemail #is there away I have a choice of what to use
  • February 12, 2026
Did you add Instant Voicemail to your Self-Serve account? You should try restarting your phone once it has been activated. https://www.koodomobile.com/en/help/instant-voicemail
