Unable to receive calls after port in my phone number to Koodo
  • November 22, 2025
  • 8 replies
  • 60 views
I can make calls and Texts but cannot receive incoming calls after transferred my phone number from Freedom mobile to Koodo. Can you fix this?
  • November 22, 2025
Have you responded to the text from Freedom mobile regarding the transfer? And did you receive a SMS from Koodo saying the number transfer is complete?
  • November 22, 2025
Did you restart your phone after the port transfer?
  • November 22, 2025
Yes, I already replied “Yes” to the Freedom Mobile text message, but I haven’t received any SMS from Koodo. My Koodo prepaid account status still shows as “Active.
  • November 22, 2025
Yes, I did
  • November 22, 2025
Unfortunately, there is limited assistance for prepaid plans in the Community. I would suggest you to schedule a callback through Koodo Assist to a working number and speak with a rep to sort out this issue. https://widget.telus.tiia.ai/koodoprepaid/koodoprepaid.html
  • November 22, 2025
When did you do the transfer? It might take several hours for the transfer to be completed. Can you check if your freedoms mobile service is cancelled?
  • November 22, 2025
I started the porting process about 10 hours ago, and I received an email from Freedom Mobile confirming that my service has been cancelled.
  • November 22, 2025
Can you check your selfserve to see if they show the static the transfer?
Anyway Your number might be stuck in the process. I would try to restart the phone every few hours to see if that can help. You can also try to call their porting center at 1-844-232-7678 or schedule a call back from Koodo
