terrible reception since upgrading my plan
  • Jul 24, 2023 5:08 PM UTC
  • 554 views
Recently switched my plan from 12GB to a summer deal 30GB for the same price. I Guess I should have known there would be a catch. I cant get cell service anywhere now, streaming music has become impossible in all the places im used to it working just fine before.  Even if im getting 2 or 3 bars still nothing will load. Can anyone explain?
Allan M
  • Jul 24, 2023 5:21 PM UTC
Changing your plan shouldn’t have any impact on your ability to use your services.
Have you tried restarting your phone, removing and reinserting your sim card, resetting your network settings, or any other troubleshooting steps yet?
srlawren
  • Hero
  • Jul 24, 2023 6:59 PM UTC
@Allan M the only thing I can think of is that most older plans were not throttled while the newer plans are typically “up to 100Mbps” throttled (sometimes with optional perk option to boost to up to double that).  I mean it shouldn’t really cause the issues the OP describes, but maybe?
  • Organizer
  • Jul 24, 2023 7:09 PM UTC
Brendan Pause
I am also suffering from really terrible internet service all over the place. Even with good reception. (This example is medium reception, but I have others with full bars, same poor connection)
Brendan Pause
Here's another screen grab taken with 100% signal. This was at the Swartz Bay terminal. Speedtest.net wouldn't even load.
