Telus TV+
  • January 22, 2026
  • 9 replies
  • 73 views
I've tried activating Telis TV+ on multiple devices; phone, TV and laptop. I sign in using my Koodo login info and it signs in fine, but on Koodo self serve it's still asking me to activate it. I'm not sure what else to try.
Darius Koodo
  • January 22, 2026
Hi there ​@PinkLux did you download the app ? We will include a helpful link here: https://www.telus.com/en/support/article/telus-tv-for-ios-android
Keep us posted on how it went.
  • January 23, 2026
I don't think Koodo's streamplus customer can use that Telus app. They typically have to use a web browser to access Telus Tv https://streamplus.telus.com/telus-login?returnUrl=%2F
  • Organizer
  • January 26, 2026
Hello,
I did download the app, and it works. But on Koodo self serve it is still asking me to activate it.
  • Organizer
  • January 26, 2026
Hello,
I can get it to work fine, on my phone and TV, but on Koodo self serve it is still asking me to activate it.
  • January 26, 2026
Hello,
Just to double check, you accessed your Koodo self serve account from your mobile device, and then went to Subscription section, clicked on Activate next to Telus Films, then you were taken to log into the TELUS TV+ app?
  • Organizer
  • January 26, 2026
Hello,
Yes, that's right.
  • January 26, 2026
@PinkLux
Try uninstalling the TELUS TV+ from your phone, then (on your phone) log into your Koodo self serve account and click Activate next to TELUS Films. From there, you should be taken to download the app and log in.
Let us know if that works.
  • Organizer
  • January 26, 2026
@PinkLux
 Done. I logged in using my Koodo info, and it works. But Koodo self serve is still asking me to activate it.
  • Organizer
  • January 26, 2026
Hello,
Yes
