swithched to monthly plan
  • February 18, 2026
  • 16 replies
  • 113 views
I switched from postpaid to the monthly prepaid plan but never received a starting code. Now  my account says
Your account has basic access for now. You'll get full access when your order ships.
what do I do next
  • February 18, 2026
That “basic access” message typically means your order is still processing; it should resolve once your SIM ships. You don’t need a starting code for monthly plans; the SIM itself activates your service.
Check your email for shipping confirmation. If you’ve waited several days with no update, you can schedule a callback through Self Serve to verify your order status, or try logging out and back in to refresh your account view. Sometimes the message lags behind backend processing.
What’s your order timeline; how long ago did you switch?
  • Organizer
  • February 18, 2026
I switched about two weeks ago. Doesn't it use the same sim I already had?
  • February 18, 2026
No, prepaid doesn’t use the same card as postpaid.
Prepaid and postpaid are actually 2 separate system, you would have to port your number from postpaid to prepaid service once you received the SIM card.
  • February 18, 2026
Hi ​@Nicg
Will you please share which steps you followed to transfer from prepaid to postpaid?
Did you use the steps mentioned here on the website https://www.koodomobile.com/en/help/moving-prepaid-postpaid-monthly-service?
  • February 18, 2026
You will need to get a prepaid SIM card first and then port over your number after registering your Self-Serve account. https://prepaidselfserve.koodomobile.com
  • Organizer
  • February 18, 2026
Thanks I'll try that
  • February 18, 2026
@Nicg
Just to clarify, are you looking to switch from prepaid to postpaid or from postpaid to prepaid?
  • Organizer
  • February 18, 2026
I think it's prepaid to postpaid
  • February 18, 2026
Got it!
Do you still have access to the prepaid account? Is your prepaid sim still active?
  • February 18, 2026
In that case, you should be able to use the Fast Switch Self Serve Option and continue to use your SIM card. Your prepaid balance will go towards your postpaid bills and the phone number will come with you.
  • Organizer
  • February 18, 2026
I can log into my postpaid account, but it says I have limited access. If I try to log into my prepaid, it says I have the wrong password or email and I can't seem to fix that but my sim does seem to be working.
  • February 18, 2026
Did you receive an activaiton email for your postpaid self-serve account and check your junk box? It usually indicates trying to register the self-serve before the email activation is received.
  • Organizer
  • February 18, 2026
I can't see an email from koodo
  • February 18, 2026
A rep will be able to help you out. You should receive a private message from ​@Flo Koodo to confirm some details and assist you further.
  • Organizer
  • February 18, 2026
Thanks
  • February 18, 2026
@Nicg We have just sent you a PM, please check your community inbox when you get the chance.
