Some calls not coming through and going straight to voicemail
  • Nov 24, 2022 1:41 PM UTC
  • 1106 views
HI,
The calls from my doctor are going straight to voice mail for some reason (most relevant on Nov 23rd, 2022). All other calls are working normally.
Was there Koodo issues that would have been relevant to this issue? I am not aware of any phone configuration I made that would have caused this.
Thanks!
Best answer by Charles Richard
The same call that didn’t come through on Wednesday came through on my phone yesterday so I consider this “done” for now.
  • Nov 24, 2022 2:14 PM UTC
Which phone model are you using? If other incoming calls were ok, you might have either blocked the number or blocked "unknown calls" in your phone. I suggest you check if that was the case.
I’m using a LG61. I’ll try checking that but as stated in the original description, I feel pretty confident there was no phone configuration changed between when those calls used to work normally and yesterday when those calls were now going to voice mail.
Thanks!
Confirming my call settings are not manipulating that number any differently.
  • Nov 24, 2022 2:46 PM UTC
Can you recheck if you block unknown calls? I recalled some numbers in the hospital have their number "hidden".
Also, did it happen only once or many times? Sometimes, it could be just a glitch somewhere either at the phone or network.
I also assumed you didn't accidentally turn on "do not disturb mode" at that time?
Rechecked and only 1 number was blocked and it wasn’t the number that brought this concern.
It happens several times yesterday on November 23rd.
The “do not disturb mode” had not been turned on.
Thanks!
