SIM card won't work
  • Jan 4, 2024 7:50 PM UTC
  • 7 replies
  • 262 views
I got a my SIM card for my phone which is an alcatel flip phone that was BELL but wonโ€™t register to work on Koodoโ€™s network. What should I do?
  • Jan 4, 2024 7:56 PM UTC
So you have your sim card activated with Koodo, and when you put it in your phone, what does it show?
  • Jan 4, 2024 8:02 PM UTC
Did you restart your phone after your inserted the new SIM card?
  • Jan 4, 2024 9:00 PM UTC
An โ€œxโ€ on the signal bars.
  • Jan 4, 2024 9:15 PM UTC
by the sounds of things, the device is locked to your previous carrier (bell). You can get an unlock code for the phone by contacting the carrier and providing them the device IMEI (this can be found under your settings in an about phone section). When you boot on the device, it should ask for the unlock code they provide. I hope this helps ๐Ÿ™‚๐Ÿ‘
  • Jan 4, 2024 9:18 PM UTC
Also forgot to ask, did you try the SIM card in another phone and is it working properly? This is just in case the device is ok but the sim isnt, always good to check first ๐Ÿ™‚
  • Jan 17, 2024 5:09 PM UTC
I do not get an unlock code option when I start the phone it just sits on searching.
ย
  • Jan 17, 2024 5:23 PM UTC
If you had the phone after Dec 2017, it should be unlocked. the X on the signal was likely with data. Have you tried to reset network settings of the phone?
as well, how did you active the sim card? Was everything ok in selfserve?
