Scheduled callbacks going directly to Voicemail
  • Oct 11, 2023 9:01 PM UTC
  • 8 replies
  • 573 views
I have two problems:
  1.  Some incoming calls to my iPhone go directly to voicemail.  Apple Help tells me it has nothing to with my phone settings and that I should contact Koodo.  I tried everything recommended on the website, including resetting my phone to factory settings. I then arranged for a “scheduled callback”.
  1. A Koodo rep called me back 3 times at the scheduled time but unfortunately they all went DIRECTLY TO VOICEMAIL!
How do I solve #1 without speaking to a rep?
if I have to speak to a rep, how do I contact one?
Best answer by vfay
I finally reached a rep who found the solution. I had the “Do not disturb “ function set to 11PM - 7AM” and although all the problems occurred outside of those hours, turning it off completely seems to have resolved the issue.
  • Oct 11, 2023 10:21 PM UTC
You could check your blocked numbers list to confirm if Koodo’s number is in the list.
  • Rockstar
  • Oct 11, 2023 10:32 PM UTC
Apple Help checked all the possible issues related to the settings on the phone.  I can confirm that the Koodo number is not blocked, it is in my Contacts and is a Favourite.
  • Oct 11, 2023 10:34 PM UTC
Is this the only number that goes straight to voicemail?
  • Rockstar
  • Oct 12, 2023 2:18 AM UTC
No, there are at least 2 other numbers, which is why I was trying to get help. Same situation: in my contacts, favourites, not blocked.
  • Oct 12, 2023 2:28 AM UTC
Which phone are you using? have you turned on any “focus mode” or special mode of your device? Can you add the call back number (1-866-995-6636 ) to your contact list?
By the way, as you are here, what was the issue that you need to call Koodo? you can ask here. Someone might know the answer
  • Rockstar
  • Oct 12, 2023 10:36 AM UTC
All the details are in my original post and reply to Goran.
  • Oct 12, 2023 2:02 PM UTC
Oh, my apologies! Was focusing on the issue of callback and mistakenly thought you wrote about the same issue.
I didn't see you mention about the iPhone model though? Was it running iOS 17? How about your signal reception in your area? Is outgoing text, calls working normally?
When you reset the phone to it's default factory settings, did you restore to the same backup? Have you tried to reset it without restoring from the backup?
  • Rockstar
  • Oct 14, 2023 3:02 PM UTC
