Recover voicemail
  • May 31, 2022 6:00 PM UTC
  • 7 replies
  • 1830 views
I recently lost a voicemail my grandfather had left me and I need to know if there's a way to recover it. I'm using a Motorola G Power and it's on Android version 11.
Any help would be deeply appreciated, he passed away recently and I just want to hear his voice again.
Best answer by Allan M
If it’s been less than 48 hours try dialing your voicemail and then dialing 19 from the main menu to see if you can recover it.
  • May 31, 2022 6:10 PM UTC
If you hung up after deleting the voicemail it's not recoverable on the customer side. When did you delete the voicemail?
Ill flag a rep for you to see if they have any options
  • May 31, 2022 6:12 PM UTC
I didn't delete the voicemail, it stated it would expire soon and that I had to renew it to keep it longer and I missed the cut off, I don't remember when it said it would be deleted.
  • May 31, 2022 6:19 PM UTC
Ah so when did you realize the voicemail expired?
  • May 31, 2022 6:21 PM UTC
I'm honestly not sure, I think the last time I renewed it was a week and a bit ago, I went to try and transfer it today and it said my inbox was empty.
  • May 31, 2022 6:59 PM UTC
Ok. Well I flagged a rep. Hopefully it can be recovered
  • May 31, 2022 7:17 PM UTC
Hello @Mschei! We are terribly sorry to hear about this.
Unless you’ve forwarded the voicemail message to someone else, once the message is removed, unfortunately Koodo has no methods to obtain the lost message.
Allan M
  • May 31, 2022 11:25 PM UTC
