I am on an iPhone 14.  I communicate by text to a family member with an Android phone. I switched to Koodo from another provider and with the switch to Koodo, I am unable to send text messages to an Android phone.  Anybody with thoughts on how I can solve this?
Are you able to send an SMS to iphone users when you turn off imessage?
What happens if you turn off RCS?
Hi Dennis,
I tried to send a text message to an iphone user with the imessage off and was not able to.    When I also turn off RCS, again not able to send text message to iphone user.
When I turn on RCS again, it states “waiting for activation”.
Hi Dennis,
It appears you didn't have any cellular signal or you might still use the old sim in your phone. You would have to make sure all sms and calling work normally first before rcs or imessage
Hi ​@Hindsee, we’re not seeing a network connection for your line.
Your number has been ported in successfully and the eSIM looks to be installed, with no provisioning errors on your account. Here are some troubleshooting steps you can try https://www.koodomobile.com/en/help/im-not-getting-any-network-service
Thank you Georgia. for this.
I did not receive my SIM card in the mail and so the support rep set me up with a eSIM instead.  I did not want to reset my phone with a physical SIM card (which is the old SIM card from my previous provider).
But thank you for the information.  I will call Support tomorrow to see if this can be resolved.
