Pixel 7 Pro Wifi Calling Carrier Activation Required
  • Jan 5, 2023 7:29 PM UTC
  • 294 views
Chris_Koodo
When I try to turn on WiFi calling in my Pixel 7 Pro, it tries for a few minutes, then says to contact my carrier to activate it. I did get ahold of a rep, but none of their suggestions worked. Any ideas is greatly appreciated.
Many thanks, Chris
Best answer by Anonymous
Hello @Chris_Koodo! We have added the VoLTE Access to your line. Please try to activate Wi-Fi Calling again.
  • Jan 5, 2023 8:20 PM UTC
I assumed you had the “volte access” addon in your selfserve. Which plan are you on now by the way?
When you had assistance of a rep, which troubleshooting steps did they ask you to do?
Chris_Koodo
  • Jan 5, 2023 8:30 PM UTC
Thanks for your contributions. I can't see a volte access add-on. I'm assuming it's on.
I'm on a monthly 20gb data plan.
They had me try to turn on WiFi calling with and without my data on, then without my wifi on. Then suggested it was Google who had to make the change.
  • Jan 5, 2023 10:40 PM UTC
Let me flag a rep here.
  • Jan 5, 2023 10:51 PM UTC
Chris_Koodo
  • Jan 5, 2023 11:26 PM UTC
It worked! Thank you very much.
