Pixel 7 not engaging Wifi Calling
  • Jan 8, 2023 3:51 PM UTC
  • 3 replies
  • 181 views
Hello 🤓
I called a few days ago and support activated Wifi calling on my Pixel 7.  When I am on a call, it still only engages the GSM network and does not engage WiFi Calling
here is what I have done:
  • Restarted the phone
  • Turned wifi calling off and back on
Hope someone can help
Thank you in advance
  • Jan 8, 2023 4:03 PM UTC
Try simulating a no-signal condition by turning on Airplane mode. You may be in an area with enough cellular signal that prevents your phone from automatically switching to Wi-Fi Calling.
When Wi-Fi Calling is turned on, your phone will automatically use an available Wi-Fi network, if it determines that you have low or no cellular coverage.
Wi-Fi Calling | Help
Thank you.  Wifi calling engaged
I will check again next call I make
is there a way to ‘force’ wifi calling?
  • Jan 8, 2023 4:08 PM UTC
The only other way is to move to an area where you have little to no cellular coverage.
