picture messages not sending
  • Nov 28, 2021 5:05 AM UTC
  • 9 replies
  • 3100 views
Yesterday I reset my networks and that erased all my Bluetooth connections. After I redid those, I can't seem to send or receive pictures messages now?
Best answer by Dinh
Your MMS proxy and MMS port wasn’t set correctly as per Koodo page above. Those value should be:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
I recommend you  fix it and see if MMS works again.
  • Nov 28, 2021 5:39 AM UTC
Which phone are you using? if it is an Android, can you check your APN settings and see if it was reset correctly as per this https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone
Also, I assumed your cellular data was ON?
Thanks. Yes it's an Android data is on and yes I checked those settings
  • Nov 28, 2021 6:00 AM UTC
Can you post a snapshot of your APN settings in the phone here? If it worked before and now it didn’t work, the MMSC might have set incorrectly.
  • Nov 28, 2021 7:05 AM UTC
MMS Port: 8799
MMS Port: 8799
Omg thank you SO much! Success! Appreciate the help!!
MMS Port: 8799
MMS Port: 8799
Very helpful! Thanks so much!!!
