phone selection
  • February 24, 2026
  • 1 reply
  • 14 views
cornerpainter
looking for advice in selection of replacement phone, there is very little to go on. I used to find at least advertising  direct  links  to each phone  Advice  hard to find, my son  has the same s23 but it  is  far better  pictures  and  speaker  .I need  a phone that takes a higher quality photo to upload and  possibly create  video  for business use. I dropped  mine in  paint it is too bad  phones  didnt  come  eqipped  with  plug  gaskets. for the ports it still  works  but the port  , not so much , a port is  good option  for backup  charging  Now  I cant  even upload . Should   I switch to apple or  continue in  android, Should  I really have two phones  for  security or  an extra line to separate work  from  recreation
1 reply
  • February 24, 2026
Any new high end phone will meet your objective for high quality videos and photos.
Regarding Android or Apple, it is solely customer preference. Personally I think if you like to tinker, android is better. If you like things to just work out of the box then Apple is better for you.
What was your old phone?
