Phone Blocking husbands number
  • Jul 14, 2022 12:28 PM UTC
  • 3 replies
  • 186 views
All of a sudden my phone started blocking my husbands number.  Have checked for updates.  Turned phone off and on.  Obviously, I did not block the number so I am unable to go in and unblock it.  Any suggestions would be great!
Boa_Guy Koodo
Hi there @BeccaJay! Its possible that you did it by accident. Here is a helpful article explaining how to block or unblock a number. :)
  • Jul 14, 2022 12:36 PM UTC
Thanks for the reply @Boa_Guy Koodo.  I did not block him by mistake and he number is not in my blocked call list.
  • Jul 14, 2022 12:48 PM UTC
Could you also check the phone of your husband and see if he accidentally turn off the “show my caller id”? Did his number showing up when he called other people?
