perks not available
  • Sep 25, 2023 11:52 AM UTC
  • 2 replies
  • 165 views
Hello, I changed my plan to get access to the Free Data Rollover perk. However, it doesn't present as an option now that I've modified my plan. I'm pretty disappointed because I have to pay an extra 10$ without the perk I wanted. Is there a way to add it that I'm not thinking of. Thank you
Best answer by Bernard Koodo
@Uhlr045 The plan you changed to does not come with roll-over-data. The Perks to choose from for the plan you picked are below:
Your new plan does come with 10 times more data than you had before, which is pretty awesome.
  • Sep 25, 2023 1:07 PM UTC
I’ll flag a rep to assist. There’s been issues with the perk changing/adding system.
Bernard Koodo
  • Sep 25, 2023 1:22 PM UTC
