open wireless home phone back cover
  • Mar 11, 2020 7:35 PM UTC
  • 8 replies
  • 396 views
Is there a video for that?
  • Mar 11, 2020 8:12 PM UTC
You would need to search for that on Google.  Search for the Make and model and then do a video search
  • Mar 11, 2020 8:24 PM UTC
why they make it so difficult to open. it is terrible .
Allan M
  • Mar 11, 2020 9:15 PM UTC
Which model do you have? We might be able to help if you cant figure it out yourself or through google.
  • Mar 11, 2020 9:38 PM UTC
zte wf723ca
  • Mar 11, 2020 9:49 PM UTC
THis is what googling got me
  • Mar 12, 2020 12:24 AM UTC
Yes, that is helpful. But, why the instruction is so misleading.
  • Mar 12, 2020 9:45 PM UTC
That is a good question.  I would blame the manufacturer for that since it is their instructions
  • Rockstar
  • Mar 13, 2020 12:30 AM UTC
On occasion I have bought products from off-shore manufactures and found that the instructions can be confusing and at times hilarious. Sometimes things get lost in interpretations. But Dennis found the answer for you.
