Oneplus open MMS FIX!
  • Jun 25, 2024 1:43 AM UTC
  • 2 replies
  • 286 views
I Recently Purchased an OnePlus open and the default message app is Google messages. For some reason I could not get MMS to work receive or send it would just be a loading symbol...Ā
I did these steps to fix mine and photos and group chats now work šŸ‘
Ā
Steps.
- Go to settingsĀ
- Mobile network
- Sim card
- Access point names (APN)
- Add APN ( + top right corner)Ā  name it differentĀ
Now with Koodo they list the APN settings you just straight copy and paste the settings link below.
Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā   ↓ Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  ↓
https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone
Next you will have two APN's delete the first one that came on your phone and use the second APN you just created with the new settings, restart your phone and now google messages should send and receive MMSĀ
Photos below cheers šŸ‘
Ā
Ā
  • Jun 25, 2024 4:32 AM UTC
Try to reset network settings and edit the original APN instead of creating a new one.Ā
  • Jun 28, 2024 2:53 PM UTC
I Could not get it to work it had to be deleted maybe a (OnePlus thing) it would always just revert to the original broken one tried everything until I accidentally deleted it once it was gone created a new one with Koodo updated settingsĀ  ( super easy to do)everything worked good 😊Ā
