OnePlus 10T Wifi Calling?D
  • Oct 2, 2022 2:57 AM UTC
  • 2 replies
  • 260 views
Ben Pointer
Recently got a OnePlus 10T and I am on Fido in Canada. I was told that wifi calling would work with Telus and their subsidiaries. Does anyone have experience using wifi calling on a OnePlus 10T with Koodo?
Thanks,
Ben
Allan M
  • Oct 2, 2022 3:20 AM UTC
There is a list here of compatible phones: https://www.koodomobile.com/en/help/wifi-calling
Oneplus phones aren’t on it unfortunately.
  • Oct 4, 2022 4:55 AM UTC
Thanks,
Ben
I do not know if you are still able to use this trick, but you can try it out and see if you are able to get wifi calling and VoLTE to work on your phone. https://community.oneplus.com/thread?id=1284987
