Number not valid
  • Mar 3, 2023 1:51 AM UTC
  • 12 replies
  • 660 views
Ted Michel
Hello,
Whenever I call anybody, my phone says the number is not valid followed with three loud beeps.
How can this be resolved?
Best answer by Dinh
Can you reset network settings of the phone to see if it can help?
How do I do that?
Also, can you dial 611 or your own voicemail?
I cannot
Which phone are you using? Normally a reset network settings should be in the settings.
Also, have you tried to restart your phone, take the SIM out and put it back again?
  • Mar 3, 2023 2:07 AM UTC
Normally if you heard that message, the number wasn't entered correctly. Did you enter the number in the format +1.xxx.xxx.xxxx? Also, did your phone work in the past?
Ted Michel
  • Organizer
  • Mar 3, 2023 2:15 AM UTC
I did and same result
It worked perfectly until today
  • Mar 3, 2023 2:22 AM UTC
I assumed you have checked your self-serve to see if everything was ok? Also, can you dial 611 or your own voicemail?
Ted Michel
  • Organizer
  • Mar 3, 2023 2:25 AM UTC
How do I do that?
I cannot
  • Mar 3, 2023 2:40 AM UTC
How do I do that?
I cannot
Ted Michel
  • Organizer
  • Mar 3, 2023 3:02 AM UTC
How do I do that?
I cannot
I have done all of this to no avail
  • Mar 3, 2023 3:12 AM UTC
This is weird, are you a prepaid or postpaid customer?  Do you have Koodo signal in your area?
Ted Michel
  • Organizer
  • Mar 3, 2023 3:16 AM UTC
I'm a prepaid customer. I think I get Koodo signal as I can send and receive text messages.
  • Mar 3, 2023 5:46 AM UTC
Can you check your prepaid selfserve to see if you still have minutes in your plan? Did data also work?
also, which phone are you using?
Ted Michel
  • Organizer
  • Mar 3, 2023 10:10 AM UTC
I still have minutes and I'm using a Samsung Galaxy A71
  • Mar 3, 2023 2:58 PM UTC
If you had another phone to try, I recommend you put the sim in it to see if the issue follows. You can also visit a Koodo kiosk to ask a rep there.
Ted Michel
  • Organizer
  • Mar 4, 2023 9:38 PM UTC
It was a technical issue on Koodo's part. The issue is now resolved. Thank you very much for your help.
