Not recieving OTP from abroad
  • Jun 29, 2022 5:59 PM UTC
  • 451 views
I am trying to receive an OTP on SMS from a company in Israel. I received OTPs from them before but now it stopped working and the company is saying that the problem is on my mobile provider side ( I am also sure of this). How do I fix this?
Thanks,
Danny
  • Jun 29, 2022 6:37 PM UTC
I’ll flag a rep for more info
  • Jun 29, 2022 8:43 PM UTC
Hello @danny57! The phone number you’re trying to receive the SMS from might have been blocked for security reasons. To get it unblocked, you’ll need to get in touch with our tech support team by scheduling a callback on koodo.com/chat.
  • Jun 29, 2022 11:32 PM UTC
Was on the phone with a representative for over an hour and a half (mostly on hold). They guaranteed me there is nothing wrong on Koodo’s side, but I am pretty sure there is, because other canadian numbers are getting the OTP fine. Very frustrating.
  • Jun 30, 2022 2:44 AM UTC
Was your phone roaming right now? And “other Canadian number” was in Israel also? If they are all from Koodo, the issue could also be the roaming partner. Can you try to manually search for other provider?
  • Jun 30, 2022 3:01 AM UTC
Do you mean roaming as in using the phone abroad? No,  I am in Canada. The other number is with Fido.
  • Jun 30, 2022 3:07 AM UTC
Oh, ok I misread your topic title. I thought you were abroad.
Receiving OTP from overseas was always challenging. There are some limitations with the shortcode (if the sender used) from oversea. If you are out of solution, you can try to change the otp number to a different one or just switch to Fido
