not receiving sms in spain
  • May 18, 2023 12:22 PM UTC
  • 8 replies
  • 370 views
I am currently in Spain with easy roam on but am unable to receive SMS texts. The issue I have is that my voicemail has also been locked, and Koodo is trying to send me an SMS with the new password which I can't receive. Can someone help me either set up the phone to receive SMS or could someone at Koodo reset the voicemail password and email me the new code to the email that I have registered on KOODO.?
Best answer by Dinh
I don't understand why I would need international roaming to receive SMS. I thought I need international roaming to send sms. I have switched all the network settings off and on.  I was wondering if I needed to connect to a specific European network for sms to come through. Right now it is connect to moviestar
You would need the add-on as they are the provisions for roaming to work. Could you add easyroam to your account as per Koodo instructions https://www.koodomobile.com/en/help/easy-roam
  • May 18, 2023 2:13 PM UTC
Could you double check your selfserve » plan and addon to see if roaming addon was added properly. You would need the international voice roaming at least to receive incoming sms.
Also, have you tried to restart and reset network settings of the phone?
  • Coach
  • May 18, 2023 2:27 PM UTC
  • Coach
  • May 18, 2023 2:34 PM UTC
I think I may have figured it out. I have an esim loaded for data access only but it was also set as the default for sms.  I've changed the default to Koodo and we will see what happens.  Thanks for your assistance.
  • Coach
  • May 18, 2023 5:43 PM UTC
Sadly I was wrong.  It didn't make any difference. When I have a strong enough signal from a provider other than moviestar I will switch and see if it makes any difference
  • Coach
  • May 19, 2023 1:02 PM UTC
Can anybody explain this?
  • May 19, 2023 1:39 PM UTC
  • Coach
  • May 19, 2023 3:39 PM UTC
Thank you, I have turned easy roam on but I don't see any change.  Does the setting take a while to update on the system or is something else required on the phone?
  • Coach
  • May 19, 2023 4:44 PM UTC
Thank you, I reset the network services and all is working.  I appreciate your help.
