I'm getting no signal on my Android Phone, tried with different things like restart, switch sims, but no luck....anybody who is facing the same issue? I'm part of Canada Ontario Mississauga
What do you mean you switched sims?
Did you try your sim in another phone and a working sim in your phone?
Are others around you with Telus/Koodo having issues?
Im not seeing any reported outages on the area
https://www.telus.com/en/on/outages
Have you logged into your self serve to check your account?
Switched sim in another phone and same issues, one of my neighbor also using koodo same issue, no signal in his mobile..…checked here many of them reported
https://downdetector.ca/status/koodo/
Are you a prepaid or postpaid customer? Have you checked if your account is active and there was no overdue amount?
I'm an active monthly postpaid customer....I can't login in telus outages.... email is not on file....
Generally, if there was an outage, they will fix it and customer unfortunately have to wait.
I assume your phone worked fine in the same area in the past? and there was no significant weather event that can cause damage to existing cellular tower?
I’m not aware of you needing to login to report an outage? It should just ask for name and phone number for personal info.
Are you still experiencing issues with the services in the area?
Login to the community
