No Reception
I am currently on Quadra Island BC and have zero reception. I am tethered to my wife’s pixel cell on Fido. I am right across the strait from Campbell river 2.2 km clear view And I have nothing on an iPhone 11 using Koodo.  She has full service on Fido;I have nothing on Koodo. Advice?  Thanks!
Did this help you find an answer to your question?
  • April 2, 2025
Hi ​@DenRV
Sorry to hear you are experiencing issues with the cell reception!
If you search manually for a network, it doesn’t find any?
Have you tried restarting your phone?
  • April 3, 2025
Flo,
Thanks for the quick reply. I was able to see multiple networks but no connection. I restarted a number of times and about ½ hour after your post it connected all of a sudden … so thank you!  Much appreciated
  • April 3, 2025
I’d also enable wifi calling on your phone as it’ll help with any random connection issues that might come up the odd time.
  • April 3, 2025
Thanks Goran
i think I spoke too soon. I just switched over from Fido to Koodo. With Fido, I could easily hook up our Hisense Roku tv and everything worked via hotspot and wifi enabled on my iPhone 11. Since switching to Koodo and even choosing my iPhone on the tv settings, it does not connect despite saying it is connected. My wife’s Pixel will connect up and the various apps and live and Roku channel work perfectly. I looked thru iPhone setting and have changed nothing. I’m stumped
  • April 3, 2025
Its possible that the Telus network has limited coverage for your location. Are you connected to Lte for network type?
