No internet when no power
  • Aug 8, 2022 11:00 PM UTC
  • 8 replies
  • 349 views
Anyone know why I never have internet when the power in my area goes out? The last time, I also had issues with texting anyone.  Can't check on power outage status let alone report the outage without internet.
Sophia
  • Aug 8, 2022 11:02 PM UTC
What do you mean exactly? That you have no data when your home WiFi is down? What plan do you have and does your data work when you are outside of your house?
It's possible that the local tower also lost power. What was your signal connection on your phone then
  • Aug 8, 2022 11:05 PM UTC
I have 8 GB data which was on, and had 3-4 bars of signal strength while the power was out. But no internet connection.
  • Aug 8, 2022 11:06 PM UTC
Is cellular data toggled on your phone? Are you currently set to airplane mode?
  • Aug 8, 2022 11:11 PM UTC
Data was on, and not set to airplane mode. My phone is set the same way as I use it when I'm in an area without wifi. Works then.
  • Aug 8, 2022 11:36 PM UTC
Does anyone else with Koodo/Telus in the area have the same problem?
  • Aug 9, 2022 12:09 AM UTC
Apparently I'm not the only one in my area.
Just hard that at times when you need the service, it's not there. I didn't try calling anyone, but texting kept giving me errors.
Allan M
  • Aug 9, 2022 12:28 AM UTC
I have the same problem in my area. We are only served by 2 towers and when the power goes out those towers get overloaded from everyone using their data since their power is it and it works...although very very very slowly to the point of me considering it not usable.
