New eSIM is locked, need PUK code
  • December 24, 2025
  • 3 replies
  • 68 views
I locked my eSIM by entering the sim pin incorrectly 3 times (I assumed it was the same as the physical card) and it now requires an 8-digit Puk code to be unlocked.
I don't have access to any other phones and I have no means of calling a Koodo rep.
Best answer by Oliver C
I'll flag a rep to help with getting you the PUK code.
Just make sure you're logged into the community using your self serve credentials and they should be able to get the info they need. 🙂
  • December 24, 2025
Darius Koodo
  • December 24, 2025
Hello ​@CMYK We noticed that you already spoke with our team and your request was addressed. Can you reconfirm if your service is working now ?
  • December 24, 2025
Yes, a PUK was provided and service is back up and running. Thank you!
