network issues
  • Jul 18, 2022 9:07 PM UTC
  • 4 replies
  • 196 views
Hi,
My phone calls keep getting dropped and the audio is really scratchy. Can you help me determine what the issue is?
thanks,
k
Allan M
  • Jul 18, 2022 11:55 PM UTC
Is anyone else that lives with or close to you having the same issues?
  • Jul 19, 2022 12:04 AM UTC
No, just my phone is having issues
  • Jul 20, 2022 3:56 AM UTC
You could try to restart the phone first. If it doesn’t work, try to reset network settings to see if it improves.
Also, was it indoor or outdoor signal?
Thanks for your reply. I’ve tried restarting my phone, and reset the network. It’s an indoor and outdoor signal that keeps getting dropped.
