Need voicemail reset
  • Oct 13, 2023 1:38 AM UTC
  • 10 replies
  • 517 views
Lost my iPhone and replaced with a new one and new SIM.
When I try to access my voicemail using the icon on the phone screen I get “Error performing request, Unknown error”
When I call my own number I get the voicemail prompts.
From reading the other reports in the forum I need a CSR to reset my voicemail, so can a CSR please help do that.
Best answer by MC Hammered
I don’t know what @Flo Koodo did on the backend, but the issue has been resolved.
  • Oct 13, 2023 1:43 AM UTC
I’ll flag a rep to see if they can do it from here. Otherwise they’ll advise you, if necessary, to use Koodo Assist to schedule a callback to reset it.
  • Oct 13, 2023 2:59 AM UTC
If you haven't changed anything and you could still access the voicemail by dialing your own number, I think the issue is the iPhone carrier settings.
Could you reset network settings of the phone with your Koodo SIM in it.? To reset, go to Settings > General > Reset > Reset Network Settings
  • Rockstar
  • Oct 13, 2023 4:10 AM UTC
I’ve reset the network settings and no change to voicemail access using the button. Same error.
I tried to enter manual configuration strings (*61*xxx) and the system doesn’t recognize them.
  • Oct 13, 2023 2:15 PM UTC
Hello @MC Hammered
We can reset it for you, however, this may delete the unsaved/unread voicemails. Are there any unread voicemails that you need to check?
  • Rockstar
  • Oct 13, 2023 4:20 PM UTC
There is nothing I need to save. Please reset.
  • Oct 13, 2023 5:33 PM UTC
Thanks for confirming @MC Hammered !
Please restart your phone and use the steps here to set up your voicemail and let us know if this fixed the issue
  • Rockstar
  • Oct 13, 2023 5:43 PM UTC
Reset my voicemail as per the instructions and still get this error when I use the VM icon or long press 1.
  • Rockstar
  • Oct 13, 2023 5:47 PM UTC
When I press “dismiss” the phone goes to this screen which does nothing. When I end the call it shows “call failed”
  • Oct 13, 2023 7:37 PM UTC
@MC Hammered Thanks forr the screenshots!
We have sent you a PM so we can further look into it, please check it out when you get the chance.
  • Rockstar
  • Oct 13, 2023 9:02 PM UTC
