Mobile Data is Not Working
  • Dec 8, 2021 8:40 PM UTC
  • 2 replies
  • 4732 views
So out of the blue today my data stopped working. There is an exclamation mark next to the status bar and I cannot access anything that involves an internet connection. I tried turning off my phone, taking out the sim card and putting it back and and turning the phone back on but that didn't work. I reset the network connections in system settings which also didn't work. I set APN back to default, didn't work. I can't get in contact with Koodo about it. Had a call back set up and when they called it just rang and rang until they hung up. Tried calling the store here and couldn't get an answer. Anyone know any other options on what to do?
Best answer by Dinh
When you mentioned about the “default” APN, what was it? did you mean you tried to reset the network settings? If possible, can you post a snapshot of your APN here. Someone might know the answer.
Also, here is the link to Koodo official APN link https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone I suggest you check it. I saw several reports in the forum where the phone couldn’t automatically set the APN on Koodo network.
  • Dec 9, 2021 2:49 AM UTC
Mark Barnard
Setting the APN helped. Just got the SIM card and activated today. Was having trouble connecting to network. Thank you!
