Missed calls
  • Nov 30, 2022 2:39 PM UTC
  • 4 replies
  • 417 views
I have recently had an issue where I’ve started to miss calls.  My phone doesn’t ring, and call logs show a missed call, but all I get is a voicemail notification.  This has caused me to miss some important calls and makes me not trust my mobile service.  I know the phone is working because in one case, they called back and it did ring and I answered.  The phone was sitting in a charger on my desk for both calls and they were only about 2 minutes apart.  I need this looked into as it makes my phone untrustworthy for receiving important calls.
  • Nov 30, 2022 2:49 PM UTC
How was your signal reception in your area? I assumed you did not turn on the “do not disturb” or “focus mode” of some sort at that time?
  • Advisor
  • Nov 30, 2022 3:02 PM UTC
I’m in an office building with glass windows, signal strength is at full bars.  On another occasion I was in my car in an area with full service. Do not disturb is enabled but turns on and off on a schedule and was off at the time of both calls.  On the last occasion, the first call did not ring, they left a message, called my home number and then called back about 2 minutes later and it did ring.  The phone was sitting on my desk the whole time.
Allan M
  • Nov 30, 2022 5:55 PM UTC
Usually with do not disturb, the first call won’t go through but the second and subsequent ones from the same number will.
I’d try disabling all do not disturb/focus modes that are enabled on the device and see if that fixes things, then you can go through and troubleshoot from there.
  • Advisor
  • Dec 2, 2022 7:10 PM UTC
Hi Alan,
Following up.  You were on the money with this.  I had thought the DND was set to end at 7am, but it was set to 8am and the calls in question came in before that.  Thanks for the help.
John
