Military Grade Phone
  • Oct 20, 2021 2:27 AM UTC
  • 2 replies
  • 312 views
Does anyone know what military grade phone will work with Koodo? I'm interested in the cat 51 phone or something like it.
Best answer by rikkster
A CAT S61 should be compatible.
CAT S62 | Caterpillar
Technical Specs > Networks: 3G, 4G & LTE (Americas).
The CAT S42 should work as well.
CAT S42 | Caterpillar
  • Oct 20, 2021 3:24 AM UTC
It all depends on the frequencies the phone is using. Do you have this information?
You can start by going here https://willmyphonework.net/
  • Oct 20, 2021 4:24 AM UTC
