LTE Calls Turned Off
  • Jul 27, 2023 1:46 PM UTC
  • 7 replies
  • 21138 views
I just received a pop-up message on my iPhone saying:
Koodo has turned off LTE calls on your account.
Why is this?
What does that mean?
Am I not allowed to make calls anymore?
Why is there no email from Koodo with an explanation?
Best answer by Boa_Guy Koodo
Hi there, @Martyn  We looked into your account, and all the lines have the VoLTE add-on provisioned, and nothing was removed or changed. Just to be on the safe side, we even refreshed the Switch in the backend. Please restart your device and let us know if anything is not working correctly.
Allan M
  • Jul 27, 2023 7:10 PM UTC
When you go to use your phone is anything working? Calls, texts, data, etc?
  • Jul 27, 2023 7:43 PM UTC
Yes, it all seems to work, but it worries me that I get a message that it’s turned off. What if it won’t work when I need to make a call. I don’t want to find out then, and then being told that I could have known.
I’m disabled and mostly make phone/LTE calls when I need help. I can’t afford to just gamble with this.
  • Jul 28, 2023 12:19 AM UTC
It is strange to hear about the LTE message. Which cellular plan are you on, was there any plan change recently?
  • Jul 28, 2023 11:56 AM UTC
It’s the $50/40GB plan. No changes since May.
  • Jul 28, 2023 12:12 PM UTC
That is strange. Let me flag a rep to help you out.
Boa_Guy Koodo
  • Koodo Alumni
  • Jul 28, 2023 1:39 PM UTC
  • Jul 29, 2023 11:45 AM UTC
It all seemed to be ok before the restart of mt phone, but restarted it anyway. It’s still all good.
That’s the confusing thing. Why the message when all is good and nothing has changed.
I think we can leave it for now; it might have been a hiccup of sorts.
Thanks to everyone that looked into this for me!
