low signal coverage inside of a house
  • May 19, 2024 10:33 PM UTC
  • 1 reply
  • 270 views
Signal coverage is significantly different outside and inside of my house. The coverage is average outside of the house, 2-3 signal bars, normal data speed connection. The moment I step inside of the house get sudenly 1 signal bar and data speed conection drasticaly drop that it is imposible to browser even basic websites. Any idea hos to solve this?
Best answer by Dinh
It happens because cellular can't travel well through partitions. Indoor signal strength, hence, depends on how many partitions you had.
To avoid indoor signal issue with call and text, you could enable wifi calling https://www.koodomobile.com/en/help/wifi-calling
1 reply
  • May 19, 2024 11:21 PM UTC
