LG K61 phone charger has fallen apart. How do I get a replacement charger?
  • Apr 5, 2023 11:40 PM UTC
  • 3 replies
  • 90 views
I have an LG K61 and the charger has completely fallen apart. Is there a way to get a replacement from KooDo?
Allan M
  • Apr 5, 2023 11:52 PM UTC
The phone only comes with a one year warranty and since LG stopped making phones in April 2021, that phone is likely more than a year old unfortunately so it wouldn’t be covered anymore.
  • Apr 6, 2023 12:20 AM UTC
Bummer. I can buy one on Amazon but thought I'd ask here first.
Thank you for your reply.
  • Apr 6, 2023 2:34 AM UTC
You can consider searching for used OEM chargers on eBay and Facebook Marketplace before resorting to a third-party product on Amazon.
