Koodo Home Phone
  • Aug 9, 2023 12:50 PM UTC
  • 628 views
I have a Koodo home phone.
If I need a replacement, is the price the same as if I were purchasing a new phone?
If the problem were just the battery, can a replacement battery be purchased?
Best answer by Flo Koodo
@HXM If it was purchased through Koodo online or in a Koodo store, the repair policy can be found here https://www.koodomobile.com/en/help/warranty-and-repair-policy
If withing the warranty period, replacement can be offered for the whole device if it is determined so by the repair center. Battery cannot be replaced separately.
I hope this answers your questions :)
  • Aug 9, 2023 5:38 PM UTC
What is the rason you need a replacement for the home phone?
  • Aug 9, 2023 6:03 PM UTC
You'd be easiest off purchasing a battery off of amazon or ebay or aliezpress or your choice of online vendor. It's highly likely to be cheaper.
À total replacement out of warranty would likely be the full price.
  • Advocate
  • Aug 9, 2023 6:33 PM UTC
I do not need a replacement for my home phone.
I said “if a need a replacement”.
I see lots of posts of people having difficulty contacting Koodo.
I have experienced some problems myself.
The person I talked to at the place that I originally purchased the phone from said they no longer sell the home phone even though when I went there to double check with someone in person I saw they have a big sign advertising some sort of Koodo package. I waited a while waiting to talk to someone about it and it appeared it would take another while before I would get to talk to someone to I left.
The AI for the self help is totally oblivious to this type of query.
So, in order to minimize my time without a phone if I should need one, I would like to know my options now.
  • Aug 9, 2023 7:11 PM UTC
To be honest, I haven’t seen what or how to go about replacing a home phone. Had mine for a while without any issues. What are people reporting on these thread you are finding?
  • Aug 9, 2023 8:54 PM UTC
  • Advocate
  • Aug 10, 2023 10:36 AM UTC
Thank you very much for that information.
In response to Robert T’s question I only recall two threads directly regarding this topic and they were both about getting an error when selecting the Koodo Home home information, but this was fixed.
