inserting SIM card into home hub
  • Dec 1, 2021 2:35 PM UTC
  • 1010 views
Dianne Blackburn
I just received my Koodo ZTE home hub.  I can’t figure out how to install the SIM card.  It looks as though the tray is recessed, but I can’t seem to get it to pop out.
Best answer by rikkster
Are you using the smallest SIM card? There are three different-sized SIM cards. The hub uses the smallest of the three, a nanoSIM card.
If the edge of the SIM card is exposed, attach a small piece of adhesive tape over the edge of the SIM card. If the adhesive tape is strong enough, this may be all you need to extract the SIM card. If using metal tweezers, a set of plastic tweezers is recommended. There’s less of a chance of damaging the SIM card. Make sure the hub is powered off and the backup battery removed when extracting/inserting the SIM card.
Precision Tweezers | Amazon Canada
There is a small symbol of a SIM card stamped into the plastic just below the SIM card slot showing the orientation of the SIM card. When inserting the SIM card into the slot, the angled cut-out is on the left side and the brass-coloured contacts face downward.
Allan M
  • Dec 1, 2021 2:49 PM UTC
Here's a video of someone putting the sim card in. Let us know if this helps
Dianne Blackburn
It did help!  Now it seems there’s a problem with how I inserted the SIM card (the red lights are flashing) and I can’t figure out how to get the card out (I’ve tried using tweezers, but I’m concerned about damaging the card).  With a phone, the entire tray pulls out, but this tray doesn’t seem to budge!
Allan M
  • Dec 1, 2021 5:46 PM UTC
Oh there is no sim tray with these
If I remember correctly the sim slot is spring loaded so if you just push inwards on the sim card it should pop out enough for you to remove.
Dianne Blackburn
It won’t move and I am concerned about damaging it trying.
  • Dec 1, 2021 11:20 PM UTC
