How to add a phone number to Favorites?
  • May 16, 2022 6:41 PM UTC
  • 3 replies
  • 169 views
 I don't see a way, either on my phone nor in the Self Serve site, that gives me the ability to add a phone number to Favorites.  I can delete contacts from the Favorites but do not see a way to add one.
Best answer by Allan M
You can do this by tapping on a contact and then towards the bottom there will be a button that says “Add to Favorites”
  • May 16, 2022 10:33 PM UTC
You can do that on your phone. Which device are you using?
  • May 17, 2022 8:09 PM UTC
@MilkyWay I have an IPhone XS
Allan M
  • May 17, 2022 11:42 PM UTC
