Help with messenger?
  • Sep 5, 2023 11:53 PM UTC
  • 4 replies
  • 265 views
The basic messenger I've been using for years now won't display images or videos but instead offers a downloadable link, which I can never download. "Tap to download", then I get "Mobile data is turned off. Check your settings." when I tap it.
I've never had data, I only use wifi. I'm not very knowledgeable when it comes to all this so a little advice would be appreciated. I'm using a Samsung A03s. Thanks.
Allan M
  • Sep 6, 2023 1:12 AM UTC
It sounds like you may have set messenger as you default texting app so now your text messages are going there and you can’t view MMS (picture texts/videos) without turning your data on.
  • Sep 6, 2023 2:01 PM UTC
Here check out this link to see what you’ve got selected since you said you’re not very good with this:
Change the default messaging app on your Galaxy phone (samsung.com)
It’ll help you follow along
  • Sep 6, 2023 11:44 PM UTC
Thanks for the advice. However, I've now switched between both the Samsung and back to my regular (Google I assume) messenger app, and neither are allowing me to see or download anything. Could it be anything else?
Allan M
  • Sep 8, 2023 1:23 AM UTC
You need to have your data turned on to download MMS (picture and video messages).
