have sim card and being prompted to add esim
  • Oct 4, 2022 12:43 AM UTC
  • 195 views
Hello,
My son’s cell phone data just stopped working today on his iphone XR and we have no idea why.
In the settings he is being prompted to add an esim.  However he has an actual sim card which was working until today.
We tried to power off the phone, he backed it up and reset to factory settings, he checked for updates and nothing so far has worked.
Can anyone explain why this has happened and how we can get his cellular data to start working again?
Thanks for your support!
Kim
Best answer by MilkyWay
We  reset to factory settings but this did not resolve the issue.
It is possible the SIM card is no longer working properly. You should head to your nearest Koodo store to get a replacement. https://www.koodomobile.com/en/help/koodo-sim-support
  • Oct 4, 2022 12:50 AM UTC
Can you try swapping Sim cards with another phone to see if the problem follows?
  • Oct 4, 2022 1:01 AM UTC
Thanks for this suggestion. I tried it and the problem did not follow.
  • Oct 4, 2022 3:47 AM UTC
If the issue did not show up in other phone, there might be something wrong with the settings of the phone. I suggest you reset all settings of the phone and see if it can help.
  • Oct 4, 2022 11:05 AM UTC
  • Oct 4, 2022 11:39 AM UTC
