eSIM problem - "Can't disable carrier"
  • Aug 12, 2023 3:02 AM UTC
  • 3 replies
  • 1072 views
Hi,
I have a Pixel 6 with 3 eSIMs: 2 unused, and 1 for Koodo (main carrier).  I decided to buy an extra eSIM for an upcoming trip on Airalo, and when I attempted to download it the process failed.  I rebooted the phone to see if it'd make any difference, but when it came back I did not have any mobile service anymore: the Koodo eSIM had been disabled.
When I try to reenable it, I see the message "Can't disable carrier - Something went wrong and your carrier could not be disabled".
I then thought that the problem might be with the other 2 unused eSIMs.  When I try to erase them from the device, I get a generic error saying that it was impossible to do so.
I've already tried:
  • Rebooting the device many times, including in Safe Mode
  • Resetting the network/mobile
  • Erasing all downloaded eSIMs (I get the same generic error)
  • Talking to Google via chat/phone
I found a few references online saying that Pixel phones can only store 3 eSIMs max., but I could not find anyone experience the exact same problem I'm having.  I'm really trying to avoid doing a factory reset.
Any ideas on what to try next?
Thanks in advance.
  • Aug 12, 2023 3:05 AM UTC
What did google say about it and to do?
  • Aug 12, 2023 3:36 AM UTC
After going through the same troubleshooting steps with them to no avail, they told me to either contact my carrier (because this is an eSIM-related issue, and they don't provide support for those) or factory reset the phone.
  • Aug 13, 2023 2:21 AM UTC
I think you might have accidentally erased the Koodo eSIM. Koodo eSIM once was removed, it can't be restored.
