dropped calls iphone
  • Oct 20, 2022 8:18 PM UTC
  • 4 replies
  • 256 views
I’m really starting to get frustrated my phone is constantly dropping calls and so frequently! It’s really impacting my business. I have just noticed that in the past 2 months the service has really dropped in quality. The calls drop every 15 to 20 minutes. Please can someone fix this? Or help me? Otherwise I may have to change carriers again.
  • Oct 21, 2022 12:33 AM UTC
There are many potential reasons for that. Which phone model are you using? And
did  it happen indoor or outdoor?
Can you also try troubleshooting steps here https://www.koodomobile.com/en/help/im-not-getting-any-networkservice
  • Oct 21, 2022 1:20 PM UTC
Hi Dinh, I find it happens both inside and outside. All areas of my home which is in the GTA just a few minutes away from Toronto. I have an iPhone 8 Plus but not sure how that might impact the quality of Koodo services.
  • Oct 22, 2022 11:43 PM UTC
It happens indoors and outdoors and I’m in Markham just a few mins away from Toronto. I’m close to a tower too. I have an iPhone 8 Plus. Could this be my phone issue? My bar is only two bars and drops calls all the time sooo frequently and I’m a business owner and trying to run my business. I need help.
  • Oct 23, 2022 12:06 AM UTC
Have you tried the troubleshooting steps as mentioned in the link mentioned above? https://www.koodomobile.com/en/help/im-not-getting-any-networkservice Sometimes a simple reset of networks settings would help.
Also, if you are having problem with indoor signal, you can try to enable wifi calling https://www.koodomobile.com/en/help/wifi-calling
How long have you been using the iPhone8plus? If possible, can you switch the SIM to another phone and see if the signal reception increase?
