Does roaming work in Zanzibar?
  • Jun 4, 2022 8:06 PM UTC
  • 214 views
My daughter is there right now. I am sure that I have activated all of the roaming add-ons, yet she is still unable to get the roaming message or do anything. She has enabled data roaming on the device.
Account number ***.
What am I doing wrong?
***edit: removed personal info
Sophia
  • Jun 4, 2022 8:44 PM UTC
Well according to Koodo’s roaming page https://www.koodomobile.com/easyroam Zanzibar is not mentioned, but Tanzania is. So I’m actually not entirely sure. Would you like me to flag a rep to confirm if Zanzibar is able to use EasyRoam?
Edit: please remove your account number, since this is a public forum. You don’t want to give hackers any ideas :)
  • Jun 4, 2022 11:57 PM UTC
Yes, please tag a rep. Also, I have no idea how to remove the phone number in the original message.
And yeah, before she left, I saw Tanzania and assumed Zanzibar would be good...
Sophia
  • Jun 5, 2022 12:02 AM UTC
I have flagged a rep. They’ll tell you more and also remove the number. No worries :)
  • Jun 5, 2022 2:23 PM UTC
Hi @Flyingpig113
As @Sophia mentioned, Easy Roam is not available in Zanzibar, however roaming should be available at pay per use rates: https://www.koodomobile.com/payperuse
Does the phone currently show a connection to a network? If it doesn’t, a manual network search in the phone settings should display the available networks that the phone can be connected to.
  • Jun 5, 2022 3:39 PM UTC
Thanks for confirming. It would be helpful if Koodo could update their list of countries available to ROAM to indicate that although Tanzania is available Zanzibar (which is part of Tanzania) is not.
Chris Koodo
  • Jun 6, 2022 1:10 PM UTC
@Flyingpig113  CORRECTION - Zanzibar IS included with Easy Roam. It’s mentioned as an eligible country on the TELUS Easy Roam page .
I went ahead and requested that Zanzibar gets added to the Koodo page as well.
Sorry for the confusion.
