Disney+ not activating
  • March 27, 2026
  • 4 replies
  • 27 views
Does anyone know how to activate this, The link does not click to accept and continue
  • March 27, 2026
that can sometimes happen when trying to activate the services. Can you try clearing your cache and cookies, using a different browser, using a different device, using an incognito tab, and turning off any VPNs you may have active and see if those do the trick.
  • March 27, 2026
First, check if Disney+ is actually active in your account; log into koodomobile.com, head to Services or My Services, and see if Stream+ shows as fully provisioned. If it’s still pending or not listed, that’s your blocker right there.
Next, disable all your browser extensions; things like uBlock Origin, Privacy Badger, NoScript; one at a time. Those script blockers love to kill the “Accept and Continue” onclick handlers, turning them into dead links. Test after each one.
The Disney+ page is picky; you have to scroll all the way to the absolute bottom of the Terms of Service before the button even lights up. Use Page Down or your mouse wheel until the footer is fully in view, then try again.
Before you go further, run through a quick checklist: Is Stream+ actually on your plan (not expired or trial)? Does the email match your Disney+ login exactly? Any open tickets or holds on perks?
  • March 27, 2026
Thank you. But all these to activate a streaming plan ? - lol
I do have the plan, cache cleared, no VPN, pop-up blocker disabled, and several devices tried including the tv, NONE Worked.
  • March 27, 2026
If you had an existing account, I would recommend you sign out of your existing device and try to re-activate again.
Typically using the incognito mode of the web browser will help if you had issue with cookies and other Adblock. If you can try to do it on a desktop .
