Data inconsistencies
  • Aug 26, 2022 10:15 PM UTC
  • 10 replies
  • 422 views
My data limit has apperently been reached on my mobile phone despite only being on day 5 of having it reset, when I check the website it says I've only used 19% of my data, but when I check directly on my phone it says I have reached the 2GB limit despite just having it reset, and now I can use my data even though I still have remaining data. I don't know what's going on and I am frustrated to no end trying to figure this out and get it fixed, as I rely on my data to check bus schedules.
Best answer by Lou
Well if I am looking at your pics properly, you don't have your phone set to match your actual billing dates with Koodo. Your phone is tracking Aug 1 to 31st, but should be tracking usage from Aug 22 to Sep 21st. It isn't automatic - your phone doesn't know what your plan is - you will have to set it manually.
The data usage on the Koodo website is what you should be going by.
  • Aug 26, 2022 10:37 PM UTC
  • Aug 26, 2022 10:46 PM UTC
I didn't know this, fixed my issue immediately, thank you so much!
  • Aug 27, 2022 1:09 AM UTC
No problem. Glad it worked out.
  • Organizer
  • Sep 3, 2022 4:41 AM UTC
The same has happened here.  Looking at usage on my phone AND on Koodo  Self Serve.  Have used all of my data in 4 days.  I have had this phone for over a year, and have never had this problem.  Any assistance would be appreciated.
  • Organizer
  • Sep 3, 2022 5:09 AM UTC
  • Organizer
  • Sep 3, 2022 5:11 AM UTC
Oops, 5 days. I am mostly on wifi.  So, it’s unclear how so much data was used.  My behavior has not changed.
  • Sep 3, 2022 5:58 AM UTC
Can you check the cellular usage section of each app in the phone and see which app was using more than normal?
  • Organizer
  • Sep 3, 2022 6:23 AM UTC
Chrome seems more than normal
My data is showing consumed even though I am on wifi. The usage calculation is very inconsistent for my number.
  • Organizer
  • Sep 21, 2022 5:02 AM UTC
I still haven’t received assistance with mine, so, I’m not sure where to go from here.
