My data was blocked after i failed to pay my monthly bill and after i payed the data block stayed and and i still cannot access my data. I get the same notifacation every time i try to use it that says i have a data block and that i can unblock it on my kudo acount but i dont have the data block addon and my bills are payed.
Page 1 / 1
Hi
I think i just did if you want to check.
Let me flag a rep to help you out.
Thank you for logging in! Ok, the data should now be active, please restart your phone and test when you get the chance. Let us know if it works!
Yep works now, thanks.
Login to the community
or
